headgasket question
iandrew89
Car: '89 Nissan 240sx Redtop SR
'94 Infiniti J30 Stock
'91 Infiniti Q45
I am going to be replacing my headgasket. The only question I have is there are so many different sizes. I've seen 86mm, 86.5mm, 87mm, 88mm all which have other options of thickness for choices. I've found the thickness I should use but can't find nothing on the 86-88mm. I have stock bottom end. What size should I be getting? thanks guys.
Hijacker
Car: '92 240sx Convertible
'94 F-150
If you're not boring the cylinders out, go with an 86mm. That's the stock size.
iandrew89
'91 Infiniti Q45
Thank you that is what I thought but I wasn't sure. Still new to all this engine internals and stuff. So I know this sounds dumb but I wanna double check. Boring the cylinders would mean I would be getting bigger pistons? As in stock pistons are 86mm and if i upgraded to 87mm pistons I would bore the cylinders out to 87mm correct? sorry for sounding dumb but I am just now getting into doing research on engine internals.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
You're correct. Go to howstuffworks.com There are entire articles on how engines work. Read through those, and then modifications are nearly common sense as long as you understand basic physics.
