Headgasket? Please help
SR20det135
Car: Nissan 240sx SR20det
Hey my head gasket blew. I am trying to replace it with a metal one. Which one should I go with Cometic(cheaper) or Greddy(expensive), also the sizes im looking at 1.2mm, 1.3mm 1.4mm? Also, the bore size on these head gaskets rangefrom 86.5 to 88mm where the standard size 86mm. Please I need help with which one to go with?
vutony
get apexi or tomei hg, the thickness of the hg depends on ur setup and how much you be boostin
apexi has 86mm size hg
http://phase2motorsports.store....html
Modified by vutony at 3:31 PM 12/11/2006
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
1.2mm is the normal i see people running. stock is .8mm i think. i run 20psi fine on the stock HG. id imagine you could squeeze another 2psi from putting a 1.2mm in. but havnt totally researched this concept.
itsnever2fast
Car: 1990 S13 HATCH SR20DET REDTOP
if you are not goin with a crazy buildup buy a 1.0mm cometic and get some head studs, measure and match to your bore...
use a 1.0mm unless you are shooting for over 20 psi boost, if you are goin high boost use a thicker gasket, plan your motor with your local speed shop. do your research.
vutony
cometic hg is a big NO NO
spider_slayer
Car: S14 240SX
S13 240SX
why is that?
i've heard of MANY people using the comic headgaskets and been fine.
vutony
if you search around, like on FA, many are have problems with them leaking
sunnys14
Car: S14
metal headgaskets USUALLY leak when owners dont get the head and block decked straight. i used Cometic on my KA-T after i decked my head and it held 18psi daily and even a 25psi boost spike a couple times on a t3/t4 57 trim. this was indeed with some ARP headstuds holding it down.
