Get you a stock Fel-Pro headgasket, some new headbolts, some gasket sealant, and have Kevin torque the head down in proper sequence, you should be just fine. Any q?s, have Kevin call me............Rookie_ca18 wrote:Any1 know of a place to get a headgasket for our motors, preferably a metal one. I know dee can get some but money is kinda tight right now. I just bought pistons and bearings so I dont really have too much money to spend. Though the fact remains I need one asap so really I guess I shouldnt be so picky. So Dee could you quote me a price for one, Kevin told me the price a couple of days ago but I dont remember. Anyway thanks ppl.
OT, but which turbo?nismoplsr wrote: I plan on upping the boost a few more pounds soon to like 20-21 psi so i can hopefully break the 300whp mark on the dyno.
I can still get those gaskets, just let me know when you're ready to front the loot.rico05 wrote:Can you get the Nismo ones still Dee? I will be back into the money money here in a few weeks and I would like to buy one.
Yes they can, post-whore .float_6969 wrote:Will the NISMO units handle and over bore? I'm .5mm over...
The answer is "Yes". But mentioning a greddy emanage on a CA just turned my stomach. You're asking for trouble. But if you have someone that has that similar set-up, then you might be alright. The CA is not the SR and they do nothing alike when it comes to performance. The CA doesn't require nearly as much timing as an SR does, so be careful.Rookie_ca18 wrote:Will the head gasket be fine running higher boost say like 18psi? I plan on raising the boost once I can get the Emanage and fuel sorted out. Well thanks.
I don't which part #s you guys are using, but I don't have that mysterious problem you're having with one bolt being longer than the others.biosehnsucht wrote:ARP SR Main Studs = ARP CA Head Studs
they fit, they work, just need one extra washer on one stud since it sticks up more.
GAH BEAT ME TO IT!!
You sure they didn't give you a bad bolt or something to that effect?biosehnsucht wrote:It's only slighty longer.. and if you don't bottom out the studs then its easy to make them all matched height but then you have almost no thread left at the bottom for the nut to torque down on
