headgasket install!!!!
fallen180sx
Car: 90 Sil80
were putting a new headgasket on the ca.. any advice from you ca peoples who have already done it? thanks homys! and thanks sean.. you were the shiz on the phone helpin us out. found out it wasnt a boost leak it was a blown headgasket. i ran it with the heater hoses chillin and it blew the gasket. so now were fixing that. then we should be back to boostin..
RMiller
Car: BBQing
Use the technique as described in the FSM. Torquing is a 2-staged, ordered process. The FSM gives the order and the specs. Besides that, make sure both surfaces are very clean and I would use a straight-edge to to make sure both surfaces are sound. Some headbolts are hard to turn, but that's because they touch the cams, so turn the cam slightly to put in those bolts.
It is very straight-forward. I reused my old bolts, but I say go for ARP studs since you'll already have the head off.
fallen180sx
Car: 90 Sil80
it wasnt the headgasket.. we have 30 compression on each cylinder. we checked, its the rings. we poured oil in there and were letting it soak.. maybe this will solve the problem. the valves are good, and my timing is perfect.. so well see tomorrow. thanks miller, you guys have gotten me thru sooo much!
float_6969
If it overheated, the head and block may need resurfaced as they are probabally warped. The CA is infamous for bad rings though and that could also be a valid problem, though I've never seen one down to 30psi...
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
its probably the rings and the head gasket. 30psi is pretty freaking low...
- tim
float_6969
It didn't run did it?
fallen180sx
Car: 90 Sil80
it RAN... but i dont think i warped anything. we let the oil soak, and gave it another compression test.. i got 157, 161, 159, and 160. i hope all of my problems are solved. were in the middle of putting it back together now.. thanks guys!
NeedCAforS13
Car: CA swapped S13 coupe
good deal. glad you figured out your problems!
Sean
fallen180sx
Car: 90 Sil80
haha well.. turns out you guys were right all along.. i have good rings.. i have a blown headgasket. we picked up the ca18de gasket off the 88 pulsar.. its brand new from autozone.. well see how she looks with her insides exposed tomorrow. ill take pics and let you guys throw me opinions on how f***** up it is.
RMiller
Car: BBQing
I don't get it. Did you blow your gasket again? The gasket isn't one of those felpro, 13.99 gaskets is it? I'd stay away from that. I bought an oem gasket, it was like $50.
fallen180sx
Car: 90 Sil80
yeah its felpro, but it was 54.12$ OEM.
