Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Thu Nov 11, 2004 5:15 pm
Well, first of all, how did the head gasket blow? Overheated? Lack of maintenace? You will need to check the head for cracks and warppage if overheating was the result of the blown headgasket.
Just have this in mind, when you buy a car with a blown head gasket or any other major engine problem, don't expect it to work once the problem is fixed. You can try to fix it and if it works... great! But don't expect it'll work 100%. If this is your first car and you have a very limitied mechanical skills, then you may want to steer clear of this car, just take your time, it'll pay off and you'll find a great car. But if you know what you are doing, then this car would be a great buy, make sure you have enough money reserved incase this engine does not work out and you have to buy a new engine. Whatever happens, good luck!
