Not bad at all, but then again, they might not know what they're up against. They're probably assuming that it just another header install, not knowing that its a PITA. You should ask them if they've done a header install on a Z before.R350Zz33 wrote: so i called a local performance shop and priced out install they said $350...
I don't know if you have to worry about emissions where you are, but last time I checked the DC headers were the only ones for the 350z that were smog legal in all 50 states.R350Zz33 wrote:i dont know what brand they are.
Your exhaust being titanium has nothing to do with power gains. CAI has its pros and cons, so does SR.phyzicxz wrote:I say keeping the stock ones is better.. not much different in power gains.. Go with cold air intake and titanium exhaust if you want a power gain.
Sigs are only displayed once per page. BTW, yours is too big. 600x200 pixels with two standard sized lines of text.aris_unlimited wrote:
**EDIT** Sorry to threadjack, but where'd my sig go?
If these are TT headers then you can't use them on your N/A as they will have mounts for the turbo's unless you take the time to try and close them up.R350Zz33 wrote:they have aftermarket headers that were removed off of a tt z and wanted to know if i was interested in buying them.
Correct me if I'm wrong, but aren't the long tubes "not smog legal"?AZ350Z wrote:We have them on special now for $323, that is IMO the best bang for the buck you can do on a Z or G.
Check the link for more info:
http://www.350zMotorSports.com
There was a company called Xerd that made a similar longtube, but they are out of business form what I have heard.
if you read i said that they were removed off a built n/a car because the guy decided to go tt. i dont know how to make it any cleareraudtatious wrote:
impossibleaudtatious wrote:How about stop being a douche?
