usdm_180sx »
https://forums.nicoclub.com/usdm-180sx-u12076.html
Sun Mar 21, 2004 11:27 am
Greddy SUCKS. The power gain is unnoticeable since it still retains the primary cat. The unit looks terrific brand new but the walls are thin and it will either CRACK when you scrape your downpipe on a speedbump or it will spring a leak eventually once the unit succumbs to heat stress. After I trashed the greddy unit I got the Hotshot and that header is TERRIFIC! You lose the primary cat so save your dp when you need to get smogged. The gaskets are cheap and thin so get new Nissan ones.
