mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Sat Aug 30, 2008 12:42 pm
In that case you're going to have to start looking for other stuff like ECU tuning, light weight flywheel (if 5-speed, this really increases response, I highly recommend one), maybe a light crank pulley (though I'm not much a fan of the underdrive pulleys myself), and if you absolutely want headers, a custom header.
If you want more than that... I'd start looking to boost it for some incredible fun. Throw in some 300ZX TT pistons and a turbo and start scaring some people.
I believe you should also be able to put in VG30DE pistons for a .5 bump in compression ratio, which will help a bit if you don't want boost. If you want to go a bit further you could get some aftermarket VG30DE pistons that are lighter and likely have a bit higher compression ratio with some aftermarket VG30DE(TT) rods for less weight as well. That should make a pretty noticeable difference... but will be quite a bit of work and be a bit expensive.
