JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Wed Oct 02, 2002 9:17 am
That is your your EGR tube (or Exhaust Gas Recirculation tube). It carries spent exhaust gasses to the EGR valve to let the ECU know its burning and then recycles it back into the mix. If you are trying to convert this to a hose, it better be able to withstand GOD AWFUL high temperatures. Disconnect the header at the cat then at the cylinder head and EGR tube to move it away from the head. I think double gasketing it tho will increase the chance of blowing one of your gaskets out.
If you want, try installing the thing yourself. Apparently your shop couldnt do it right. Unbolt everything from it then start over, but start at the cylinder head to MAKE SURE it seats properly. Where it connects to the exhaust may be off a few, but you can loosen the exhaust, bolt the 2 together, and retighten the exhaust. As for the EGR tube, mine was a b**** to get back on, but it will go.
