Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu May 27, 2004 3:14 pm
what i'm curious to see is the clearance issues. I helped install a Pacesetter header on my friend's MX-6 and we ran into a similar problem with the EGR tube. We ended up having to cut it off with my hacksaw and them rigging a plug for the header.
Nobody had a fitting large enough to plug up the bolt hole, so we took the stock plug, had it filled with weld, then welded the collar in place.
To fix the EGR tube itself, we got some cold weld and crimped the tube leaving a few inches to fill with the cold weld, and then crimped the end.
I want to know what the clearance for the tube is in case something needs to be cut.
