That is a good idea but would require a 3 axis wire cut EDM. I was thinking of swedging short tubes flared out to fit better then build from there.LEMHEAD16 wrote:I'd like to see them made out of a little thicker material than 1/4" I'd think you would see some warping at 1/4.
1/2" it is then!
Is it possible to make the head side oval and the tube side round 1.5"
Hey, that's a good idea. maybe the Titan headers on ebay could be cut and welded to the stock VH flanges? I have a Q45 still in the car so I haven't been able to compare it. I'm still worried about how much I would have to modify the ebay ones, They might not tuck in the Z. I want to run side pipes so I might just have to build off the stock VH flanges. How is your project coming?ktzed wrote:Whats wrong with cutting the pipes off of the stock manifold and using the flange? Also, did you see the VH/VK header thread a couple down? I am doing a 240z project as well and am going to try using modified Titan headers.
vk56-manifolds-t534903.html
