head unit
Post all your Nissan electronics, car audio and stereo questions here!
mandoz85
I just instaled a new head unit in my 89 240sx and my problem is that the radio works when the car is in the on position but as soon as i go to turn the car on the headunit goes off. It wont turn on when the car is is running. as soon as i turn it off then it turns on again. Could this be caused buy a low battery.Thanksmandoz85
Rockenreno
Car: 1997 BMW M3
I'd check to make sure you have the power wires going to the correct places. There is a good descriptoin of which wires do which somewhere here, I found it when I was installing my head unit.
mandoz85
i fixed my problem all i have to do is turn on the car and then jiggle the key and the head unit turns on.thanks
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
Ok that doesn't sound good... You might want to replace the key assembly cuz if you have to do that for your stereo.. Your car might die on you one day while your driving... Get that fixed
