VG33QX4 »
https://forums.nicoclub.com/vg33qx4-u162332.html
Sat Dec 11, 2010 8:30 am
ALRIGHT so i did the install last night, flawless. worked fine on the first shot. i grounded straight to the chassis on left hand side there is a nut that holds the frame together. simply loosen the bolt put ground on and tighten up. unfortunetly the radio bezel did not fit with the wood grain. but still looks good anyway, its such a tight fit anyway. the sound is simply amazing in my opinion. super clear at volume and alot more mids. totally impressed i recommend to all the sony cdx-530ui perfect blue match to led gauge lights. the usb feature is awesome super fast transitions.the radio reception increase is insane. i can pull stations that my stock radio could not.
the volume is perfect just as stock in regards to the ability of adjustment level 1-10 is how it should be and not loud, like someone had said in posts i saw. it was stated aftermarket radio would be loud at low volumes and distort at high. this is not true. it works flawlessly no static no nothing. use the regular nissan infiniti harness dont waste your time and money with the rca one.
getting the brackets off the factory head unit required a impact electric drill
i used generic nissan/infiniti metra wire harness, metra radio adapter and metra din universal din kit.
