Holisticbeatz »
https://forums.nicoclub.com/holisticbeatz-u5589.html
Sat Dec 20, 2003 10:05 am
I'm not exactly sure which wire to tap in either. I bought a Kenwood headunit and installed everything but the illumination/dimmer wire. I believe the wire is suppose to be tapped into the gauge cluster light control wire on the cluster harness. So when the lights illuminate inside the gauge cluster, a signal is sent to the Kenwood headunit telling it to dim.
I couldn't find the wiring diagram. So on my next day off, I'm going to borrow my friend's light tester and find the wire myself by testing it. Hopefully I'll be successful. Unless you want to just tell me which wire it is, I'll appreciate it.
