head uniit on s13 problems
Post all your Nissan electronics, car audio and stereo questions here!
Bob_Sagat
Car: 1993 S13 Hatch
I tried installing a jvc head unit in my s13 recently. I followed all the guides I found online, and it worked, but it wasn't hooked to a constant 12v source apparantly. I didn't save presets, etc. I went back to mess with it and make that work, but now It doesn't work at all. And my main problem is that all the interior lights (dome light, footwell lights) don't work now. Why would installing a radio affect the interior lights. I'm totally at a loss here, any help would be appreciated.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Sounds like you blew a fuse or two. How did you make your connections? Twist and tape? Solder and heat shrink?
w8lifter21
Car: '91 300zx TT, 99' Honda Accord
Check the dome fuses and your ground. Worst case, just run a new 12v constant and ign wires to the ignition.
tc240sx
Car: 1991 240SX Hatchback
my car did the same thing when i put my deck in the first time. turned out to be just a fuse.
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
happened to me. exact thing happened to me. you have a blown fuse for sure, and definately check your grounds. make sure you are grounded properly, and u replace ur fuses, and you'll be good to go
