I have to agree.... Thats actually not the extreme wear side either.. the main thrust is on the cam cap side... If none of the metal has distored into the bore of the cam journal, and the cam doesnt hit anywhere else... put it back together...KATwo40 wrote:There's nothing protruding into the bearing surface area, so I think I'll just bolt it up and roll with it.
I'll be ridin' durty.
Haha, but i thought it was "derrty"I vote for using the spare. You don't know what happened, or what the problem was/is. You are playing with fire, man, and RPM are the gas. Also, don't forget to have the cam checked out thoroughly if you will be using it.KATwo40 wrote:I'll be ridin' durty.
