Head tolerance...
KATwo40
Car: 1993 240sx KA-T
Well, I checked the head tolerance with a Snap-On straight edge, and had one place that could fit a .002" feeler gauge under it...this was near a water jacket, away from where the fire rings in the headgasket will be. I tried .0025" and it would not slide under the straight edge.
Is .002" close enough for the Fel-Pro gasket to handle? The block deck will be milled, if needed, but I'm thinkin' this head is gonna be ok.
This is for a 400ish whp/wtq engine w/ 8.8:1 CR.
Thanks in advance.
12valveturbo
Car: s13
Yea max warpage is .004 so you should be fine.
Chezedik
Car: 1991 Nissan 240sx
If you are using Cometic or some other MLS, I would get it cut.
KATwo40
12valveturbo wrote:Yea max warpage is .004 so you should be fine.
Thanks. As I mentioned before, it's not even near the fire-ring area, so I'm sure it'll be fine.
Isn't it funny how on this car, max warpage is .004, but I've seen smallblock Chevy V8's run up to .010 with a Fel-Pro gasket!
Crazy.
Chezedik
You would be fine with a Fel-pro, but MLS is a whole different monster. That ***** has to be perfect to use that kind of gasket.
