Head Swap Questions / Need Answers to finish
DaydreamDrifter
Car: 90 240sx 00 Altima
Does a chain gude ned to be ground down somewhere? Glacier, Did your throttle cable need to be lengthened? What is the hose to that comes from the black think to which the master cylinder is mounted, the hose is against the firewall and now sits in the air beside the intake manifold. Your help would help me go back to work and go buy weed. PLEASE HELP.
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
You gotta find out where your cover is hitting and go from there, try some clay lined on the inside of your cover where you think it may be hitting. That will show you exactly where the problem is. As far as the rear black tube thats the brake booster vacuum source and needs to be hooked to manifold.
DaydreamDrifter
i tried using a window pen, like what a dealership would use, but it didn't work and i don't have any clay, why would i have clay? Thanks i need to find a new hole for the brake booster to tap into.
