Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Thu Nov 04, 2004 9:46 am
The cam shaft spins at one half crank revolution on all engins..... sometimes the intake cam it turned by the crank and then the exuast cam is turned by the intake, wich will make them turn in diff directions to that it could maby turn the distributer backwards(realy not sure about that just that if the cams spin in diff directions on a de and there is only one direction on an e there wuld be a chance if it was powerd by the exaust cam) however I am almost positive that on the DE both cams are turned by the chain in the same direction, so every thing should be spinning at the right speed in the right direction...
