head swap costs
240DRFT
considering ka24de head swap on my sohc, just wondering how much a ka24de head costs. thx
eddiec
Car: 91 S13
i paid 50 shipped for a head minus cams. paid 150 for motor minus accessories. the extra one is to practice porting.\ and general abuse.
eddiec
Car: 91 S13
240DRFT
where'd u find the head for sale ?
eddiec
Car: 91 S13
over in the parts forum.
sentranator
Car: cars and hockey
hey i read alot about people putting the dohc head on the sohc block, what is that going to do for you could someone explain . i guess its a noob question i jsut am not understanding the whole reason for the swap.
jason
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
high comp DOHC power without much work. Swapping heads is easier than pulling/swapping pistons.
Read: more power for cheap
blacks13ek
sentranator im new to cars but from what i read on nico you have one cam bring in air to ur engine, and another exiting exhaust gases instead of One doing all the work
Twinchy
Car: Peg leggin 240sx
how much hp can you gain like that and is that safe for the motor?
S13ChucKAT
Car: asd
well.. more than the KA24DE has stock.. its like a higher compression KA24DE.. so... stock DOHC has 155/165.. add about 10hp, also you always have to use premium
Twinchy
what is needed to do the head swap
nab911
Car: 93 Nissan 240SX SE
It will add a lot more than 10hp. You are raising compression from like ~9.7 to 11.7... My guess was ~200 tuned with race gas.
Twinchy
$200 tuned.....including parts and labor. does anyone of you guys know who can do this in so cal? this is very interesting i didnt know this was possilbile
nab911
Lol no, 200 whp tuned :). Ill tune it myself because i can burn eprom chips
Twinchy
awww... do you know how much this swap would cost?
TeckniX
nab911 do you have any pre-made maps corresponding to a nice ~200whp tune of a ka24e with a de head, so technically a higher cr ka24de ?? I'm going through the swap and was lookiing for a nice program to run in the ecu.. and it seems u've already done the tuning.. so would u like to share the wealth?
w1ngzer0
Car: Pfft. i don't own a box
nab911 wrote:It will add a lot more than 10hp. You are raising compression from like ~9.7 to 11.7... My guess was ~200 tuned with race gas.
Will just droping the DE head work with 91?
nab911
TeckniX wrote:nab911 do you have any pre-made maps corresponding to a nice ~200whp tune of a ka24e with a de head, so technically a higher cr ka24de ?? I'm going through the swap and was lookiing for a nice program to run in the ecu.. and it seems u've already done the tuning.. so would u like to share the wealth?
Lol.. no i have my e torn down and i gotta pick up the de this week. Those numbers are just my guesses based on others experiences. Once i get this whole tuning thing down, and start writing maps ill be glad to send out the maps/chips.
blacks13ek
nab911 wrote:Lol.. no i have my e torn down and i gotta pick up the de this week. Those numbers are just my guesses based on others experiences. Once i get this whole tuning thing down, and start writing maps ill be glad to send out the maps/chips.
i look forward to this
TeckniX
cool cool.. well I might beat you to it.. I've already got the head I just need to get around to tearin' into the e, then adding the de stuff, and then tuning it :) wide band should be in the mail, so after that I'll just hook it up with some nice higher cr e maps, and tune it for my de ;)What do you think? Also can you take some pics of your e torned down... and how much of a pain was it.. I'm really wondering if I can tear it down and swap everything in one day???
S13ChucKAT
Car: asd
you really pulling some #'s out of *** right there..
im saying 170hp/185 tq. to the flywheel.. maybe MAYBE 150/150 to the wheel.
mello88
Car: s13
Hi all
I have both a 'de and an 'e (90 and 92 240s), but my 90 'E has a blown head gasket. The other night I was thinking about just biting the bullet and replacing the gasket... And what an (apparent) PITA it would be.. Since you'd have to pull the timing chain, so you'd have to pull the front off (pulley, fan, rad, etc).
Anyway it sounds like it would be quite a bit of work to pull the head -- but even once it's off wouldn't you need the timing chain setup (chains, tensioners, guides, etc) from a DE to make it all work? What else is needed for this conversion?
edit: doh
This sounds like a great idea :). Anyone running a conversion, if so did you before/after dyno?
S13ChucKAT
Car: asd
pretty much a full head (manifolds/intake stuff, fuel rail/injectors, head, cams, timing chain, cam gears, valve cover, head gasket) a full DOHC timing kit, a custom plate to mount a SOHC lower timing cover, to a DOHC upper timing cover.
