MojoMan »
https://forums.nicoclub.com/mojoman-u2671.html
Thu Dec 04, 2003 8:24 am
It's one problem after another thats taking me in further and further into the motor. First of all I was doing was valve stem seals when one of the half moon pieces in the valve spring assembley went some where in my head or else where as I thought. I probed around for a while with a magnet tool hopeing to locate it with no luck and used an extra one I had. I go to put everything back together and realize the t- chain jumped a tooth. I pull the front t chain cover to realign it and realize the cover does not go back on without the head or bottom end being pulled. So last night I am getting the head ready to pull which is not that hard until Im losening up all of the head studs and to my amazement one of the head studs striped a little soooo....huh....I take a deep breath and continue to tap on the tool that you use to get the studs out with and eventually I think to look inside the studs top and I see the lost half moon smashed inside the top. So now I have to find a way to get the smashed half moon out and some how get the stud out. Any ideas after I get the half moon out and the stud still wants to not turn?
