head strength on boosted KA
cosmo
So just how strong is the KA-DE head. Is there a certain limit on what level it needs to be upgraded at?
Here are my plansWD Stage 1(when it gets done)8.5:1 comp Ross PistonsPauter RodsFel Pro head gasketARP head boltscams(haven't found any specs, suggestions? Good idle is a must)
Would I need to upgrade the valves, springs, etc....
Thanks
SingleCamSam
From what i've seen on most high powered KA's, porting and polishing does little to nothing, but good gains can be had from upgrading the cams to 248/248 duration.
red240ne
Car: mmm...donuts
SingleCamSam wrote:From what i've seen on most high powered KA's, porting and polishing does little to nothing, but good gains can be had from upgrading the cams to 248/248 duration.
hahaha, you haven't seen much then!! Port and Polish for a KA is like magic. A good Valve angle job never hurts for a KA either.;)
LT_Z
I saw an article for porting a KA head in the back of a magazine i had but i cant find it. Does anyone know which one it was or who has a write up & pics on effectively porting the KA head ? Also ive heard weird things about upgrading the cams on high boost engines, whats a good upgrade from stock for a highly boosted engine ?
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I dont know about that, cuz' I just read about a fully built turbo KA hittin' 504 rwhp @ 27p.s.i. ...........on stock bumpsticks!!!
cosmo
any recommendations for 248/248 cams?
Xero
Modified Mag did that article, the one I just picked up is talking about bottom end rebuilding and machining. Good series, good mag too
SingleCamSam
Quote »hahaha, you haven't seen much then!! [/quote]Check out Chris May's site and dynos. He had Sunbelt port his head and it looked like an outstanding job. Unfortunately he actually lost power through most of the rpm range as compared to a stock head. Lost about 3 peak hp too. So i'll say again, the stock head is fine even beyond 400hp to the wheels.
LT_Z
Hmm, OK maybe i just do some mild flow workmyself. Yes ive seen the "mike lee" 504rwhp on stock cams. But i need to buy new cams for my rebuild and im not wanting to buy some other ones a few months down the road. So im looking for a descent cam upgrade for a high boost motor. ANy suggestions ? Ive read that actually "over caming" hurts perfromance in turbo engines for some reason ? not sure tho
Nathan
overlap bad
solarex
any idea on how much boost the stock ka would hold???!
Nathan
2psi before the flux capacitors are overrun with termites.
cosmo
solarex wrote:any idea on how much boost the stock ka would hold???!
Damn thread stealer!!!!!!!!
Nobody has given a good cam recommendation yet, even though it's been asked now 4 times. Somebody give the info
LT_Z
Yes Please :) Im just wanting something a little better than stock, I live in CA so i will have to smog on 0psi, should be no problem as long as the cam isnt outrageous, who are some manufacturers for our SOHC KA's ? thanx again !
SingleCamSam
Shadbolt cams in Canada will custom grind an SOHC cam made for turbocharged applications. Give them a call (do a google search to find the number, it's on their site but i don't have it handy). Talk to Barry. Nice people to deal with. :)
Structure240sx
if u want sumthin jsut a little better than stock go with 91 cams. 248/240 i think right? i have them in now and they make a difference n/a. and they are cheap too
solarex
cosmo wrote:Damn thread stealer!!!!!!!!
sorry bro! ;) abit sidebar, but still in the topic.
Nathan
It's not JUST 91's that have those cams, 92's and apparently some 93's do as well. As for holding boost...I can name several people making between 320-350whp on stock bottom ends. The engine is sturdy enough as long as you have perfect tuning and no detonation. The two I'm thinking of are both running JWT ecu's too...probably not a coincidence. Conservative tuning = stock engine living.
Structure240sx
yea i thought it was 92 too never heard of 93 have the good cams.
but yea ill be goin with jwt also for tuning. they know what they are doin and i def do not
