deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Jul 06, 2004 3:31 pm
If you still have your full set of shims, you can get them installed properly it will just take some time. Ok before i go on, if you plan to get this head rebuilt (valves ground, etc..) make sure your machinist matches the installed valve stem height to oem. When valves are ground, they sit deeper in the seats > valve stem is also moved. This should be checked, and stems may need to be ground down for correct height.
Ok back to the first comment, you can get all the shims in correctly (with stock valve grind, or lapped valves). You will be spending some time torqing and untorqing the cams, and using a feeler gauge to check tolerance for each 16. Just keep swapping them untill they are all within spec (.013-.016" iirc). If you have the valves/seats machine ground on this head, the stems will need to be checked/ground to get them back to what they were oem. The stock shim arrangement should still work properly. I have been able to get this done, with stock shims, on 2 japan de heads and 3 mexicos.
On that note, be aware that japan de heads (240sx), mexico de(altima, truck) and US de (altima, truck) all use different thicknesses of shims and are not interchangable. Good to know if your out looking for a shim.
BTW. If the head is rebuilt for performance application (arent they all?) and the valves are sitting deeper in seat, unshroud them for better flow.
