Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Sat Jan 02, 2010 1:08 pm
Yes, there is no need to have your engine at TDC cylinder 1 for a head removal. As soon as you pull the cams out all the valves will be pushed up by the springs.
When reasembling you can manually set the pistons at TDC using the crank pully.Then when you place the head on you just make sure your cams are possitioned correcly (10 and 12oclock) and your engine will be perfectly mechanically timed
