head question
1989240sx
Car: 1989 240sx and 1974 duster
how are is it to change out head gasket
slowerthanyou
Car: 1993 Nissan 240sx, 2001 honda civic
not to hard at all just make sure you put everything back on timing.. and keep a fsm nearby,,
1989240sx
is there still a way to get the fsm online
slowerthanyou
1989240sx
so i just need to take the intake off but it is being a pain to do know i found two bold that where hold it to a bracket is there anymore that i dont know
1989240sx
so i have everything pull of the intake manifold but it does not what to move does anyone have pictures of what needs to be remove so i can see what i miss
shanelach
Car: N/A
You need to take the head and intake manifold off at the same time. There are studs on both sides of the intake manifold which make it so it cant move in either direction. Just remove your header and your good to pull it straight up and out.
ramal
Car: 1992 nissan 240sx convertable
It's not hard at all but it is very time consuming. be prepared to spend a good weekend on the job. all the info you need to do the job is located in the tech forume
1989240sx
so got the head off thanks for the help guys i have to say the head are lot lighter than the cast iron ones also does anyone have pic on the hose in the back area
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
I might but which hose? heater core, egr tube, other
martins_240sx
all I got
1989240sx
were the egr is at also nice built on your car
martins_240sx
those are for the heater core if you are referring to the silver wrapped hose....if that is it i can tell you which one goes where since there is a inlet and outlet hose
1989240sx
i have question would port and polish be worth the money to do on my heads i plan on keep the engine for awhile
martins_240sx
If you found someone to do a good cheap deal
1989240sx
would i get more performance out of the engine
martins_240sx
very little... you would have to get other stuff done to notice a dramatic gain
1989240sx
what else do i need to get done what i have plan was to do exhaust and intake keep it a non tubro engine
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
doubt you would notice much. hows the head gasket replacement coming?
89twoforty
Car: 89 fastback
I'm curious as well. I'm replacing my buddy's for him this weekend, and am deciding if I want to tear into mine soon as well.
Never hurts to do the maintenance before it's completely necessary.
1989240sx
so i got my head back on and timing chain cover back on too so have little bit more than i am ready to drive my 240 again i also still have to install my injen air intake i am going to wait on that to make sure that i have no oil leaks also does anyone know the torque spec on time chain cover bolts
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
well, it sucks I didn't see this earlier because for 80 bucks you can get a cam ground by oregon cam grinders for your car. Its pretty easy to get the cam back off on a SOHC though. So, think about it. peace.
1989240sx
so i have finish everything and started it up and it started to make a noise that i never use to make i have no clue what i could be does anyone know what it could be ?? i have video of the sound this sucks
http://s136.photobucket.com/al...5.flv
martins_240sx
sounds like mine did....I think the lifters just need to bleed out some of the air...
1989240sx
so what does that mean i just need to run the car for a while to do that. I am hoping that it is not a bent valve
martins_240sx
i just let mine idle and itfixed it....hope its not a bent valve though
1989240sx
i want to get studs for my heads where would i go to get them
