Postby
float_6969 »
https://forums.nicoclub.com/float-6969-u780.htmlThu Mar 31, 2011 7:44 am
It's been done on the CA18, but I have yet to see any evidence that the CA18 has the same oil pooling problems that the RB does. I've personally had my motor at about 7K rpm in 5th gear for about 30 seconds straight and I never saw any drop in oil pressure indicating oil starvation due to the pan pumping into the head.
I have it, its a simple modification and i have seen some engines "throwing out" oil from the ventilation under high rpm for a period of time.
I dont see any "downsides" to it.
I have 2, one on each side of the head.
Very overkill but thats how i like it.
Postby
tommey »
https://forums.nicoclub.com/tommey-u123469.htmlSat Apr 02, 2011 3:25 am
No, the circle you marked there goes to the water passage.
The two holes on either side above that is where i mount these.
They are just press fit and some liquid gasket for extra sealing
