HEAD LIGHTS COME ON BUT NO SPEEDOMETER AND CLOCK LIGHT
tony96
Car: 1993 infiniti j30t
I HAVE A 93 J30T WITH 128K. MY HEADLIGHTS COME ON BUT MY SPEEDOMETER LIGHT AND MY CLOCK AND THE REST OF MY INTERIOR LIGHT DONT ILLUMINATE. ANY ADVICE WOULD HELP
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think the fuse is seperate for the illumination circuit.. Might chekc the fuse/relay...
metaverse3
tony96 wrote:I HAVE A 93 J30T WITH 128K. MY HEADLIGHTS COME ON BUT MY SPEEDOMETER LIGHT AND MY CLOCK AND THE REST OF MY INTERIOR LIGHT DONT ILLUMINATE. ANY ADVICE WOULD HELP
Check the switch stalk itself. 93 J30 failure of accessories turning on is a known issue. There is a service bulletin that I linked to here: zer...0.pdf
Take a look at it. To replace the electronics of the ignition cylinder, you have to pull the drivers knee panel and the ignition column shroud. You cannot get the shroud off without removing the knee panel. There is a tab on the ignition shrould that settles behind the knee panel and it won't flex much at all.
