Gerardjg »
https://forums.nicoclub.com/gerardjg-u36599.html
Thu Mar 06, 2008 12:18 pm
It is not the relay itself it is the solder joint from the pin connectors to the circuitboard, I was able to pull one at a junkyard, I did all of the solder work on that and just swapped them out, no more flashing lights and my lights are brighter Inside the case are 4 enclosed relays I also opened them up and cleaned the points with contact cleaner. The unit I took out did not have covers on the individual internal relays same part number.
