I had it set up on a different tap and it went through... so stfumudvayne9790 wrote:did u really bump after 13 min
tried it... like 20times no luckbersh240 wrote:why not just crank it down by hand.. then plug motor back in.. and see if they work?
and btw.. why the bump.. feel lonely? awww
Modified by bersh240 at 12:21 AM 1/26/2010
ok its like this... umm hit the button to make the head lights go down... the good one went down... then next the one i hit went up... so there i unpluged it turned it down and pluged it back in... it stayed down.. but when i hit the button to go up... they go up but then then other one goes right back down lolbersh240 wrote:dont tell mudvayne to stfu.not nice.
and are you saying that if you reset the motor by hand then turn the lights on the one goes down and other stays up then they both light up? or just the one thats up?
what u mean controller? just the head light motor Manuel controller or is there something eles? o yea the brown wire was cut i reconnect it a while back thobersh240 wrote:by any chance did you do the cut the brown wire.. or have a headlight controlelr?cuz mine did that today after i was chop choping wires out from under my dash and headlights went wacky like that. i sent headlight controoler to 0. then put them down. them set them to 80. went up then down. then zero again and it went back to normal..either that or somthing in the headlight motor broke and it only engages somtimes.someone else that has more headlight powers please step in noww
yea, i guess its a cheap way of doing sleepy eyes but id rather just do it manual, cuz i heard it can mess up ur electrical light system later onbersh240 wrote:oh boy...you need to do some reading.
a headlight controller is aftermarket and controles how far you headlights close. pivot is most common.and cutting the brown wire is just a cheap way to do it its inside the headlight switch.
kid ur lucky idk you cuz ill break ur f***ing neck. f*** this place people like you have there head so far up there a**. have fun with what mommy an daddy bought u... o yea wouldnt reply cuz ill never get on here again . thanks have a nice day.. f*** you peace of s***heartofaskyline wrote:you fail at life. /thread. fyi your car sucks
