Note that the higher color temp on those bulbs comes at the cost of brightness. The color change is accomplished by removing some (higher wavelength) light. That only applies to halogen bulbs, not LED replacements. OTOH LED replacements for exterior halogen bulbs are illegal in the US (I'm not 100% sure about that).TripleblkQX wrote:Totally, I got some ultra white bulbs
Do you mean the W5W? I believe that most of those are filtered to be red or yellow, the exception being the license plate light.TripleblkQX wrote:Might just leave the high beam as is and just replace the 168 bulb with a white/4300k.
The lights... so mesmerizing...
LEDs are quite legal, they just have to meed the required light output, as long as the beam pattern conform to legal requirements, LEDs are okay. That said, most aftermarket LED low beam systems aren't bright enough to be legal. And the beam pattern usually way off.ralfp wrote: Note that the higher color temp on those bulbs comes at the cost of brightness. The color change is accomplished by removing some (higher wavelength) light. That only applies to halogen bulbs, not LED replacements. OTOH LED replacements for exterior halogen bulbs are illegal in the US (I'm not 100% sure about that).
Just to clarifyralfp wrote: Do you mean the W5W? I believe that most of those are filtered to be red or yellow, the exception being the license plate light.
AFAIK replacing a DOT headlight bulb with a different bulb (e.g. H7 with HID or HB4 with HB3) is illegal in the US. The only legal replacements are those that the fixture was designed for. A doubt an LED bulb could meet the H8 photometric specs. What I'm not sure about is whether the rule applies to front fog lamps (they probably do not).mk15 wrote:LEDs are quite legal, they just have to meed the required light output, as long as the beam pattern conform to legal requirements, LEDs are okay. That said, most aftermarket LED low beam systems aren't bright enough to be legal. And the beam pattern usually way off.
LED are legal as long as they meet the DOT requirements. There's nothing explicitly against LED lighting. If an LED direct replacement for the HID or Halogen meet the DOT standard (proper illumunation, color temp, distribution pattern, etc..) it would be legal. And there are legal LED headlamps, just not for the modern variety style of headlamps: http://www.optronicsinc.com/oemtruck13-new.htmlralfp wrote:AFAIK replacing a DOT headlight bulb with a different bulb (e.g. H7 with HID or HB4 with HB3) is illegal in the US. The only legal replacements are those that the fixture was designed for. A doubt an LED bulb could meet the H8 photometric specs. What I'm not sure about is whether the rule applies to front fog lamps (they probably do not).mk15 wrote:LEDs are quite legal, they just have to meed the required light output, as long as the beam pattern conform to legal requirements, LEDs are okay. That said, most aftermarket LED low beam systems aren't bright enough to be legal. And the beam pattern usually way off.
Edit: Unless things have changed recently, it's illegal in the US to replace a high or low beam bulb (not sure about others, e.g. fog) with a different bulb, regardless of whether or not the new configuration meets legal photometric requirements.
Neat on the sealed beams. I guess we agree that that LEDs cannot be used as a US legal replacement for H7, H8, etc. bulbs (because such things do not exist). Based upon a brief skimming of the applicable FMVSS, it appears that this does not apply to fog lamps.mk15 wrote:LED are legal as long as they meet the DOT requirements. There's nothing explicitly against LED lighting. If an LED direct replacement for the HID or Halogen meet the DOT standard (proper illumunation, color temp, distribution pattern, etc..) it would be legal. And there are legal LED headlamps, just not for the modern variety style of headlamps: http://www.optronicsinc.com/oemtruck13-new.html
Sorry, I guess I was being pedantic. But yea, as it is, there's no drop-in LED replacement that work. Although I've seen a few LED bulbs that are getting closer when used in projector housings. Just need better beam pattern, and maybe another 400-600 lumens more.ralfp wrote:Neat on the sealed beams. I guess we agree that that LEDs cannot be used as a US legal replacement for H7, H8, etc. bulbs (because such things do not exist). Based upon a brief skimming of the applicable FMVSS, it appears that this does not apply to fog lamps.
As for why LED replacements for halogen bulbs probably won't be available any time soon... the legal specifications for replaceable bulbs specify things like the location of the filament (see NHTSA-1998-3397-0032 here). I do not see how LED based bulbs could meet a requirement for filament positioning. In my brief skimming of the FMVSS (108), I see that filament can mean any light emitting source (§ 571.108 S4), but the actual numbers seem to preclude the use of LEDs for H8 (and other halogen bulbs).
