fairladyztt12 »
https://forums.nicoclub.com/fairladyztt12-u158930.html
Fri Apr 23, 2010 5:04 pm
First I'd like to start by saying yes i have checked the bulb and swapped the bulbs and it doesnt change the problem.
I recently bought a 1991 JDM 300zx TT. it has HID lights installed if that makes a difference im not sure. all the lights on the right side of the car works fine but on the left side my HID wont turn on, the low beam comes on slowly and the high beam also wont turn on. as far as the HID's go ive swapped the bulbs and the ballasts and the problem stays the same ive inspected the switch and dont see an corrosion or anything the fuse in the relay box marked H/lamp LH (15A) keeps blowing so i assume that is closely connected to the problem. i Appreciate any advice you can offer!
Thanks
Gordon
