onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed Mar 08, 2006 1:07 pm
simple test:
pull the headlight.
Probe the 3 wires for the headlight connector on the side that works to figure out:
1 wire = ground1 wire = lo beam1 wire = hi beam
Now, do the same for the bad side.
if you get power to the hi beam wire on the bad side, then the problem lies w/in your headlight (you can also swap headlights to test this).
If not, you will need to continue tracing backward.
The headlight relay box is on the driver side below the intake inlet (not sure if this is high beam, but there are lots of relays for headlight control there).
You may want to d/l or buy an FSM (search you can d/l for free). There are testing procedures in there.
