Head light issue...pass. side high and low works Intermittently..HELP!!!
nine3j30
Car: 1993 infinity j30
im having trouble with my pssenger side headlight on my J30.The issue is as follows:when I turn on the headlights my drivers side high & low always work fine, but my passenger side works for a couple of minutes then goes out a couple of minutes later it comes back on and this continues to happen over and over...Whent the pass side goes out both high and low are out..when the come back on both work. which leads me to believe its deffinatley not a bulb issue because high and low are individual bulbs.Ive cheked and swapped the fuses under the hood, still no luck. Could this be a relay issue? and if so where would it be located? any help is appreciated. thanks
yodawill2000
Car: 94 Infiniti J30
Very common on the J's http://www.fuzzycats.com/docs/headlight_relay.pdf
Welcome to NICO !!!!
nine3j30
thanks for the info...very helpful. i'll be getting into it this weekend. i'll let you know the outcome.
driverdriver
Car: NICO's longtime resident Canuck!!!
Don't exceed the bulb wattage (55w is the max) or you'll melt the wiring.
Skapunk4everr
Car: 95' j30
My relay went bad about a year or so ago. From what I remember it took about 30min to get the new one installed and has worked well. I would recommend buying a new one from Nissan because they are only about $40.
