Postby
ANDRE-TRismGen »
https://forums.nicoclub.com/andre-trismgen-u57761.htmlSun Aug 26, 2007 6:43 pm
well they work its just that the drivers side is dim.i looked at the wiring behind the headlights and the previous owner had the h/l's wired to each other so i unwired it and wired every thing back to stock but the drivers side h/l doesnt work..does any body know what the problem could be.
Postby
Redevil »
https://forums.nicoclub.com/redevil-u51177.htmlSun Aug 26, 2007 6:51 pm
most likely it/s a bad switch. If you want to ghetto rig it you can put it back to the way it was, or do what I did. I opened up the steering column shroud and jumped the left and right side lowbeam wires together. Don't remeber what colors the wires were though.
