carfromhell »
https://forums.nicoclub.com/carfromhell-u216502.html
Mon Feb 25, 2013 6:07 pm
Replacing head gasket, had head surfaced & valve job done. I torqued the head down with new bolts & washers (washers installed correctly) cleaned out all the holes prior to torquing down head. First go around broke # 3 head bolt when tighting to 59 lbs bought all new head bolts,washers & gasket. Second go around break #5 head bolt before reaching 59 lbs. Both times FEL-Pro bolts were installed. I will be picking up new head bolts in the morning (different brand) along with washers, & gasket. I have a clicker torque wrench & the "old School" sweeping arm torque wrench both are working good.
Question is has anybody else had this problem? Has anybody ever heard of a shim being installed with the head gasket? I feel that it's the cheap a** fel-pro bolts made in tawain. I remember buying some about 10 yrs ago and three were bent when I opened the box. The parts house is throwing me all these questions as they said nobody has ever had this problem with fell-pro head bolts. Whats your thought on this?
