Radian »
https://forums.nicoclub.com/radian-u7167.html
Mon Jun 14, 2004 10:15 am
I had a motorcycle head worked on a while ago. I was not really looking for performance, so I just had basic stuff done. Valve lapping, stem seal replacement, bead blasting the ports and paint off the outter surface.
You could have larger valves installed, there would be a lot of tuning and support parts to install though. More gas+air=more boom.You could have the intake/exhaust ports enlarged/polished. Same as above.You could just polish existing port sizes. This smooths air and exhaust flow into and out of the head creating less turbulance and a slight increase in power.
The short of it is any modification you are going to do to the head will require a major money and time comitment. I would suggest just cleaning the head and bead blasting it or even painting it if you want to get wild.
This is obviously your daily driver, and you will appreciate a reliable, well running engine far more than a setup that runs +7hp but is never tuned correctly and costs an arm and a leg.
just my $0.02
