ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Sat Apr 16, 2005 6:34 am
I found the problem. Also, neither the head or block are cracked, had that checked when it was there at the machine shop too. Water is indeed entering through the cylinder via head gasket. Don't get me wrong the head gasket is doing it's job, there is just this other problem. Here is my post from FA that I have posted.
"The head and block was verified flat when I got it back from the machine shop via straight edge. It still is flat, as I've removed the head yet again today. I've now run into a new problem that means I want a new block. I do not want this block anymore, it is my new door stopper. The new problem I've found seems to be one of the problems I thought was fixed. When JGY gave me this motor (fully assembled), the sleeves seemed a bit pushed down below deck a little when I finally tore it down due to the same problems. After machining and such, I had it flat as can be with the rest of the block face. Well now, it seems all sank down again except #3. I've measured and 1+2 sank about 0.3mm. #4 sank 0.9mm (wierd it sealed the best by looking at the pistons, 1+2 were shiny as hell, 3 was muddy black, 4 was fine charcoal black with no moisture). Unless there is anything that can fix this sinking sleeve problem, I will use this block as a JGY showcase and move on to another block. I may be searching for a short block soon. I also have some CP 90mm pistons and 89mm pistons as paperweights. What a week."
