Head Gasket
coolcloo1019
Car: street racing
Alright, I think that my head gasket is gone. I've been having sputtering problems a lot and white smoke. But the thing is, I compression checked it and all the cylinders are between 140-150 which isnt too bad. But I checked my oil today and it was milky :( . So I'm thinking it is the gasket. Also I am losing coolant. Have to put more water in every 50-60 miles because it starts to overheat. Anyone have any ideas besides mine? Thanks
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Sounds like the headgasket, might want to post on the mechanic section :)
yellow_jacket
Car: 95 240sx
Considering that this is a SOHC you probablyt have had chain noise. This is significant because the sohc chains like to rub holes in the coolant passages of the front cover. Pull your front cover and look for holes. Also, do not drive the car with coolant in the oil! It will trash your bottom end
