head gasket
zache803
Car: Ca18det powered 240sx
im trying to decide which size metal headgasket from hks to get. either the 1.2 mm or the 1.6 both are 86 bore? the price difference is about $15 dollars on http://www.nengun.com. but before i bought anything i wanted to get some of your opinions.
Thanks
float_6969
IIRC 1.2mm is the stock thickness, unless you're compensating for material removed from the head and block, I would stick with the stock thickness. Thicker head gaskets are a poor way of decreasing compression.
zache803
does anyone know where i can find a metal headgasket besides from nengun.com because their shipping cost a **** ton.
Thanks
Chris859
Well, the Cometic is awesome especially for the price - $100, or ACL makes an mls headgasket for the ca18, also good - like $110. I think greddy makes one for around $180. And unless you are going for a decently high amount of boost the oem nissan headgasket for the ca18det is just fine as well.
psilocyben
Car: 1992 240sx
If you afe interested modyourcar.com.au has copper head gaskets.
zache803
well how much can the stock head gasket hold? planning on running about 15-18psi somewhere in that area
Chris859
I believe when I was reading around, staying under 18psi on the stock oem ca18det headgasket will be just fine. However, I decided to go with a cometic head gasket and studs instead for the added protection when I decide to go higher than 18psi.
