head gasket?
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
So i took my car to the shop today to have em look over the cooling system. Replace thermo check for leaks and see if they kno why she is overheating. Guy took the car in, replace thermo flush and filled rad. Took it for test drive and it still over heats, and now is smoking out the tail-pipe. Everyone at the shop said its a good sign of a blown headgasket.......thing is i havent ever seen tailpipe smoke....im lost
anyone know if it is indeed the gasket
how hard is it to replace it myself?
its a 92 S13....(KADE)
chrislis
Car: 1998 240sx sE!
well they're right about one thing, smoke out the tail usually tells the tale f a blown head gasket, happened to my buddys car a couple months ago.
ILikeMy240sx
Car: SR Power
what color is the smoke? smoke due to blown HG is white...
Id atleast check for compression if anything. Check your oil for milky sign. Also see if your coolant inside the rad bubbles when you run your car.
It would be ALOT easier to change the HG with the engine out of the car but you can still do it with it in the car. I think you have to unbolt the engine mounts and raise the motor a little too.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
ha definately not, you dont need to unbolt the motor, and headgaskets on this car are still really really easy with the motor in the car
you can do it yourself, youre gonna want to download a copy of the FSM and follow that word by word
i have 2 240s that ive owned a for little over a year and ive done five headgaskets, i even forgot about two of em....
i dont remember how long it took me the first time, but eventually i was ina situation where i had to swap the heads on the two cars
i removed and installed both heads in just under 8 hours.... 4 hours a headgasket, but both were done in the exact same steps
ILikeMy240sx
Car: SR Power
It would be easier to take the front cover off with the motor raised a little no? I dont know what its like to change the HG on a KA but on a SR, I wouldnt want to change the HG on it with the motor still in the car...
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
no, plus you only need to pull the upper cover anyway, so its still really easy on the KA
the only ****ty parts are the vacuum lines on the back of the head and two of the intake manifold bolts
240TweakerNewbee
Car: 1989 Nissan 240SX
Take the KA out and give it to the salvation army... then put a real motor (SR20DET) in it, and as long as you don't crank up the boost you won't have to worry about head gasket problems.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
yes the smoke is white
havent check the bubbling ****, but i got a ntoe from mechanic that quotes: "Bled coolant system, replaced thermostat. Believe there to be head gasket blown or cracked head."
240DRFT
have u checked your oil yet. it should look like choc milk if its bad
dfw240_EE
Car: 1992 240SX
Doesn't thin white smoke also mean running rich sometimes? Particularly when accompanied by the smell of gasoline?
Thick white smoke though I believe means headgasket.
Bruno240
it wouldn't be white if it was running rich. gas doesnt burn white it would be black.
black- running richwhite-coolentblue-oil
i believe that is right. correct me if im wrong
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
however, i had a very warped head... very means 0.008 inch, but still, the overflow tank gurgled every time i drove it
no smoke, ever
many head gaskets later, head swap
aluminum heads on iron blocks are gonna have a tendency to warp pretty easy. alls im saying its possible to not have water in the oil or smoking and have a massive head problem.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
cars currently not at home so i didnt check the oil, i do know however soemtimes when i was driving before the temp gauge would sky rocket, i would hear a "boiling" sound coming frmot he engine bay and it continued for a short while after i shut the car off....im assuming thats cause it was over heating...
grimple1
Car: 95 240sx Zenki
if it gets too hot you can blow the HG and warp the head.....Had it happen on my old accord. Didn't notice the heat gauge and *poof* blown HG and warped head.
lee.
240TweakerNewbee wrote:Take the KA out and give it to the salvation army... then put a real motor (SR20DET) in it, and as long as you don't crank up the boost you won't have to worry about head gasket problems.
Go read up on the KA, it's an amazing engine that most don't know about. Don't be so quick to judge about an engine you know nothing about. The KA is just as a real ENGINE as the SR. I prefer a engine in my car, 20+ batteries in the car to power a motor doesn't fly with me.
dfw240_EE
Car: 1992 240SX
grimple1 wrote:if it gets too hot you can blow the HG and warp the head.....Had it happen on my old accord. Didn't notice the heat gauge and *poof* blown HG and warped head.
It's worse on Hondas, all of their vehicles are aluminum blocks. There even the block will warp!
drifter_for_life06
Car: Daily: '16 WRX
Exocet
lee. wrote: I prefer a engine in my car, 20+ batteries in the car to power a motor doesn't fly with me.
WTF?!
dfw240_EE
Car: 1992 240SX
drifter_for_life06 wrote:WTF?!
If you notice, 240TweakerNewbee said:"Take the KA out and give it to the salvation army... then put a real motor (SR20DET) in it, and as long as you don't crank up the boost you won't have to worry about head gasket problems. "
In the strictest engineering sense of the word, a motor refers to an electric motor, and an engine refers to non-electric kinetic energy generators (like a gasoline piston engine).
I think that is what lee was referring to. It's splitting hairs really. Like how I still write conductance as Mho (Ohm backwards, get it?) when the "new, proper" terminology is Siemens.
