hey all,I removed all the bolts to the intake and exhaust and i took out the fuel rail and removed the valve cover...
kinda got stuck here seeing as the cam sprocket has a bolt that is like 1inch in size... so i gotta go grab a big enough socket to remove it.
My question is. I already removed the distributor, and I did not set no.1 to TDC. Is this going to run me into problems.
Also, it seems like I can get the head off without taking out the fan and rad housing.... do I NEED to take this out like the fsm says?
Also... any suggestions with stabilizing the timing chain? What reprecussions am I in for if it happens to slip?
I used a plastic garbage bag to cover the injector and spark plug ports... will this suffice?
thanks as always,ss240
