Zeller »
https://forums.nicoclub.com/zeller-u122819.html
Wed Jan 21, 2009 5:31 pm
Okay, so you had a boost leak on the hotside of the IC. Depending on how your set-up is and how big the leak was you could have very easily over spun your turbo (your turbo doesn't know there is a leak, so it is still going to try and reach your set boost pressure) and blown the seals on it and now be leaking coolant into the exhaust side of the turbo and burning it off, white smoke. Had this happen on my evo: Had a bad throttle body leak and over spun the turbo and it just poured out white smoke! Change the HG and run the car again. If it is still smoking, I would say it is your turbo.
