Jezz_s13 »
https://forums.nicoclub.com/jezz-s13-u1779.html
Thu Apr 01, 2004 6:01 pm
I wouldn't go further that 2mm no, that would give roughly 8:1.the problem with running thicker than std thickness HG is that you reduce/remove the squish area, the squish helps to mix the charge as the piston rises on the compression stroke, removing it can lead to poor mix and det.That said that's quite theoretical, the CA does seem to cope pretty well with thicker HG's.
You should definately find out if your pistons are low comp or not first though. if they are std they will be flat topped (bar the valve reliefs) if they are low comp they will be dished.
