ericthered »
https://forums.nicoclub.com/ericthered-u77371.html
Tue Nov 27, 2007 6:47 pm
These engines don't have a history of blowing head gaskets pretty much ever.
First question is whether the timing chain guides have been replaced or not. When these fail the timing chain can jump... it is an "interference engine" meaning that when wrongly timed, the vales can make contact with the cylinders, resulting in general very badness. This is a common problem in 1993 and earlier Q45s - you read about it in many many posts.
Usually the engines just stop, and don't overheat first, AFAIK. Did your overheat, or was it just hot? I don't know if there is a possibility that the engine can still turn OK if the valves are already bent out of the way. Others with more experience here will know more.
In any case, if its not chain guides, then I'd start looking at other issues before declaring it is a head gasket.
