Head gasket replacement information wanted KA24
tumolt
Car: 1993 240 SX SE
Overheating problems sidelined my car. I replaced radiator, then water pump, and finally the thermostat. Also the radiator hoses. Seemed ok for a while. Then after recent replacement of motor mounts the car overheated on the way back from the shop. Mechanic said wait til the car burps. So I opened the cap on the radiator (hiss), it burped and I tighten the cap back down. Temperature gage went down to normal range. I drove home no overheating. But it happened again. I am going to remove the thermostat and try running the motor without it to check the flow throught the cooling system. I know it is highly unlikely that a year old water pump may be defective but I want to check it out before thinking there is a problem with the head gasket. I never took this motor apart and if the problem is in fact the head gasket I want to know beforehand what I would have to do. Ugggg!
donmada
Car: 91 240sx with a s13 black top sr20det
i just ripped the head off my ka theres not much to it at all well i had mine out so it will be a bit different if urs is still in the car but other than that its not bad at all
jaytv1019
Car: 1995 240sx w/redtop swap
I doubt you have a problem with your head gasket.
1) How much coolant did you put in? If you "thought" you filled but there was a air bubble and you burped the system, the coolant level would go down and you would over heat.
2) When you burped the system did you top off the coolant?
3) Have you noticed that you are burning any coolant? smoke or smell from exhaust?
When you replaced the whole coolant system, you open yourself up to a TON of air bubbles. I would monitor how much coolant is in there and give "burping" the system one more try.
