Head gasket question
Quicsilvia
Car: s14
Im replacing the head gasket on my ka and i plan to go ka-t...what would you say is the best head gasket to use...cometic maybe??...i want a good strong gasket that doesnt require buying new studs
Altimasurgery801
Car: 1993 Nissan Altima
nissanfanatic
Car: 1992 Nissan 240sx SE
I currently use re-used stock headbolts and a cometic.. I used moly lube on them.. Works great so far..
boznuttz
Car: MS13
You won't need a Cosmetic unless you wish to push higher numbers, there just is no point to it. You would also have to shave the head to have a surface perfectly flat within a hundreth of a millimeter. You would be fine with an oem head gasket from any local Nissan dealership, I just personally like Felpro, lol.
Suicide.Veteran
Car: 93 Nissan 240sx
jack. Are any of the ports or internal lines s'posed to be covered by the HG? I have one that covered some and i have had a small leak in the back of my block since like the first day, but everything stays lubed.
boznuttz
Car: MS13
jack?
boznuttz
Car: MS13
What headgasket do you have?
Suicide.Veteran
i got a felpro....
boznuttz
Car: MS13
Are you posotive you put it on the right way?
Nissan_240sx
Car: 1992 240sx
Felpro ftw, installed mine about a year ago w/ no problems
boznuttz
Car: MS13
It REALLY sounds like you might have messed up something then...among the Nico users using Felpro head gaskets, there really aren't any complaints. If you covered up and oil and coolant passages, it's CERTAIN you didnt install it properly.
Suicide.Veteran
LOL theres only one way to install it dude. Ive been doin rebuilds for a while too.....
nissanfanatic
I never resurfaced my head. All you really have to do is make sure it isn' warped, clean the surface really well, and spray it pretty good with a couple coats of copper spray. I wouldn't have used one, but I figured it couldn't hurt after pushing out one gasket and then lifting the head with ARPs..
