qwade25 wrote:Couple days ago I had changed out the head gasket. I got the felpro hg. Pulled the head off. Sprayed the hg with copper spray then put everthing back together.
I was looking around to see if everything was on right. Then I noticed that part of the hg was sticking out from the back on the drivers side. Then today I got on here (nico) and saw some pics of how the hg goes on. I got to thinking and I think I put the hg on wrong.
My question is can I reuse that head gasket that I had sprayed copper spray on it? Its only been about 2 days since I put it on or will I have to get another hg? When I got it all back together, I started it up for about a minute. It didn't sound right so I turned it off. Haven't started it ever since
Yes, you can re-use your headgasket. I have used a stock headgasket to break-in one of my motors (5,200miles) with 20psi of T3/T04E boost, tore it down, cleaned the same headgasket with brake cleaner, let it dry, and sprayed the H/G with copper spray a 2nd, and re-used the head for a 2nd time and it worked just great. Now the car is apart for a seriously ported head, cams, racing valve springs, etc, and I will be using a cometic headgasket this time around. But the stock AJUSA gasket was still in great shape after all of that.
Dee
