OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Sun Nov 29, 2009 6:07 pm
So no major smoking or steaming, is there oil in the coolant, or coolant in the oil?
First, fix the oil leak
Then do a compression test.
Then try the basics, inspect all sensors and connection, make sure they are all clean and not corroded. Check the fuel rail for leaks (injector O rings), Maybe give her a tune up (cap, rotor, plugs, wires) and time it, replace fuel filter, and clean the MAF (MAF Clean), maybe a seafoam job.
