PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Thu Jun 11, 2009 5:45 am
If you have any exhaust leaks, you should be able to hear them.
But yeah, it never hurts to replace the gaskets. Just pull the manifolds. I replaced my head gasket with a stock unit when turboing my car. Stock is pretty darn good, and also acts sort of like a fuse if anything were to go wrong, you'll blow the $50 headgasket as opposed to blowing something else more expensive. Anyway, here is how you change the headgasket:
Pull the valve cover(optional like I said) remove intake and exhaust manifolds- they can be a PITA sometimesremove the cams and upper timing sprocket- make sure you put your engine at TDC Compression stroke before doing any of this, and mark up your sprockets with each chain so you get your cam timing right when putting it all back together
you also might have to remove the vacuum distribution block off the back of the head, as well as the EGR tube (not sure, I removed my EGR), and the engine grounds.Clear any wiring out of the way (disconnect it from anything and swing the harness to the side)Now you can start removing the head boltsTake them out, and pull the head off... try not to pry it too much with anything thin... as the head is aluminum and is easily scratched/scuffedremove headclean spilled coolant from cylinder boresreplace gasketinstall is pretty much reverse of removal. Use new head bolts or upgrade to re-usable ARP hardware (I strongly suggest this especially if you are going turbo).
Its pretty well outlined in the FSM, which is available free online... There is a link in my sig.
