Head Gasket Fitment :(
StryfeS13
Car: 1993 Nissan 240SX
So, I ordered this head kit with all the gaskets etc, and I noticed the valve cover gasket, and spark plug gasket thing dont fit properly. It's like they were meant for a different version of the KA. So I immediately thought, oh s***, the head gasket is probably different too...
It lines up with everything except one single bolt on the front timing cover, can I notch it out to fit, or should I just go get a head gasket from pep boys?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Do not skimp on the head gasket, get the correct one. Get one made by Felpro at the very least.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
That for an altima KA
motaro9424
Car: 240sx convertible
Yeah ..probably it is from the Altima, they look the same but they are different.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
sx moneypit wrote:Do not skimp on the head gasket, get the correct one. Get one made by Felpro at the very least.
gaskets are sumpthing you cannot go cheep on..they can cost you the motor if you choose a chepo and it fails...ie head gasket,exhaust manifold gaskets..ect....some of the gaskets you can actually make from a roll of matirial..i buy felpro gasket in a roll for water pumps and coolant issues...but i only use the best for my build when it comes to headgaskets..dont skimp...felpro or better...good luck
sx moneypit
1986 Toyota MR2
Good piece of info OutToWin.
StryfeS13
I got it all figured out guys!Uh, I went to order a felpro gasket for a 91-94 but it still would not fit, turns out that only the 95-98 gaskets fit in my car, which is a 93.
This means I have a swapped motor?
sx moneypit
1986 Toyota MR2
Apparently so, Alldata shows a different part #.
liquid_cool
StryfeS13 wrote:I got it all figured out guys!Uh, I went to order a felpro gasket for a 91-94 but it still would not fit, turns out that only the 95-98 gaskets fit in my car, which is a 93.
with 240's you should allways ask what mods have been done before you buy..that way you will know to buy say...90 parts for the body and trim and 95-98 parts for your motor..ect (example)....you should actually make a note book on what your car has moded and keep it just in case you decide to sell it or need to refer to it later when doing maintinance...this will allso help you keep track of regular oil changes and problems you may have been having...hope this helps.
